Product info: Non - NXP platform + 88W8997 AZW AW-CM276NF module.
Customer is going to do BT logo certification and they have below question:
1. Will NXP share your BLUEZ code base or BT Host QDID to customer?
2. or when the product which is using NXP WiFi-BT combo chip but non-NXP platform; this case uses 88W8997 module + Sigmastar platform/main CPU.
can customer directly use the NXP HOST QDID: https://device.report/bluetooth/129162
Thanks.
Customer's note below:
- "https://device.report/bluetooth/129162 | Declaration ID: D052927 (52927)"
Customers can qualify their end products by combining different qualification listing QDIDs together, still, please consider that while there is a pre-certification they will still need to certify their end application as there are differences in the hardware and there might be some modifications in sw configuration that might affect the performance.
regards,
