WM8974 codec setup
WM8974 codec setup
1,641 次查看
leonardogiordan
I have a custom board using Vybrid processor.
We are trying to add audio support using WM8974 codec, using i2c + i2c
IC codec seems to be working (i2cdetect shows is at 0x1A)
However, Im not sure about changes on devicetree and/or linux/sound/soc/fsl/fsl-asoc-card.c)
This is my device tree sound related:
sound {
compatible = "fsl,imx-audio-wm8974";
audio-cpu = <&sai3>;
audio-codec = <&wm8974_codec>;
status = "okay";
wm8974_codec: wm8974@1a {
#sound-dai-cells = <0>;
compatible = "wlf,wm8974";
reg = <0x1a>;
clocks = <&osc 0>;
I also added at fsl-asoc-card.c:
} else if (of_device_is_compatible(np, "fsl,imx-audio-wm8974")) {
codec_dai_name = "wlf,wm8974";
priv->card.set_bias_level = fsl_asoc_card_set_bias_level;
priv->dai_fmt |= SND_SOC_DAIFMT_CBM_CFM;
On dmesg I got:
[ 0.283707] fsl-asoc-card sound: ASoC: CPU DAI (null) not registered
[ 0.321637] fsl-asoc-card sound: ASoC: CODEC DAI wlf,wm8974 not registered
WM8974 is enabled at kernel (not as a module).
Any tips or suggestions?
BR,
Leonardo
标记 (2)
1,227 次查看
smvankampen
Hi Leonardo,
You should adapt de kernel config to include the codec. But you probably already found out.
Do you have a working solution with the wm8974 codec in the meantime? I have all drivers registered, but get pcm_write errors. Probably due to some clk configuration I think.
Stephan
