I'm going to hold a training for students a bout DSP. It will include concepts like SIMD, VLIW, Fixed point, ...etc concepts. I was searching for an example to be used in this training and I found that SC3850 DSP is suitable. Also I studied it well in my work. SC3850 is a strong DSP which includes a lot of concepts to be discussed with students.
In order to use SC3850 as in example for the training I need the following documents:
What are the steps should I do to use these documents in the training ?
I inquired as to what you needed to do to use the documentation and there is nothing you need to do. You can simply use the material.
Andy
