Data acquisition system for Kinetis K Family
Author : Mauro Padin (Student)
Supervisors : Professor Daniel A. Jacoby, Juan Pablo Vega (Teacher Assistant)
Summary:
This project is based on the FRDM-K64F board, a HC-05 Bluetooth module, and a smartphone. In this application, an analog signal is sampled and transmitted wirelessly to a smartphone, using an external Bluetooth module, where it is displayed. The complete CodeWarrior C code and MIT App Inventor code can be found in the .zip file.
System Structure
SysTick Module: Periodically triggers ADC conversions and UART transmissions.
ADC Module: Samples the analog signal and manages the ADC input buffer.
UART Module: Manages the UART output buffer and transmits the digitized data.
Bluetooth Module: When connected, wirelessly transmits the data coming from the UART module.
Smartphone App: Handles Bluetooth connection, receives the digitized data and manages the display.
Software Structure
A project template is provided to the students in order to establish a simple, and easy, program organization for the duration of the course. A portion of the template was built with the help of the Processor Expert so that, later on, the students would be able to understand its structure and limitations, and transition to this new tool. A wrapper was built around this auto-generated code and the resulting function, void __LDM_init (void), is to be used at the very beginning of the project given. This function mainly configures internal processor registers related to clock configuration.
The project is composed of separate files for each hardware and software module:
  • The template is composed of four files: LDM.c/h, main.c, and misc.h.
  • The application is found in: App.c/h
  • RTI, ADC, UART, LED Drivers are defined in: RTI.c/h, adc.c/h, uart.c/h, and LED.c/h.
The basic Driver structure consists of a void DRV_init(void) initialization, a set of void DRV_x_ISR(void) interrupt handlers, a set of void DRV_x_PISR(void) periodic interrupt handlers, and a set of void DRV_x services function. Only the initialization function is mandatory, the others being optional and dependent on the driver purpose. Service functions are interfaces between the application and the Driver and do not necessarily access any subjacent hardware. Indeed, this Driver structure can be nested and thus not handle any hardware at all. When a Driver function does access hardware, it is recommended to further use a Hardware Abstraction Layer to enhance productivity and improve portability.
Extracts of the system
As an example of the Driver Structure, the LED Driver is described below:
init
void LED_init  (void)
ISR
N/A
PISR
void LED_PISR  (void)
Services
void LED_write  (color_t color, bool value)
void LED_set  (color_t color)
void LED_clear  (color_t color)
void LED_toggle (color_t color)
The entire application is interrupt driven, so that only initialization are necessary and the run loop is empty:
void App_init(void)
  LED_init();  // LED driver init function
  uart_init();  // UART driver init function
  adc_init();  // ADC driver init function
  RTI_init();  // RTI driver init function
void App_run(void) { }
Hardware interrupts are not serviced in their specific handler but referred to external handlers for readability and organization. The SysTick interrupt handler is composed of a ISR and a Service:
ISR_t SysTick_Handler(void)
  LED_isr code
  ADC_conv code
The code for the smartphone side is depicted below:
Finally, a screenshot of the result:
Original Attachment has been moved to: -ADC-bluetooth-TP6.zip
标签 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1129275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKinetis%20K%E7%B3%BB%E5%88%97%E6%95%B0%E6%8D%AE%E9%87%87%E9%9B%86%E7%B3%BB%E7%BB%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2018pt%3B%20font-family%3A%20Arial%3B%20color%3A%20%23000000%3B%22%3EKinetis%20K%E7%B3%BB%E5%88%97%E6%95%B0%E6%8D%AE%E9%87%87%E9%9B%86%E7%B3%BB%E7%BB%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23000000%3B%20font-weight%3A%20bold%3B%22%3E%E4%BD%9C%E8%80%85%20%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3EMauro%20Padin%EF%BC%88%E5%AD%A6%E7%94%9F%EF%BC%89%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23000000%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23000000%3B%20font-weight%3A%20bold%3B%22%3E%E6%8C%87%E5%AF%BC%E8%80%81%E5%B8%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2015px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23000000%3B%22%3E%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3EDaniel%20A.%20Jacoby%20%E6%95%99%E6%8E%88%E3%80%81Juan%20Pablo%20Vega%EF%BC%88%E5%8A%A9%E6%95%99%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3E%E6%91%98%E8%A6%81%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E8%AF%A5%E9%A1%B9%E7%9B%AE%E5%9F%BA%E4%BA%8E%20FRDM-K64F%20%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%81HC-05%20%E8%93%9D%E7%89%99%E6%A8%A1%E5%9D%97%E5%92%8C%E4%B8%80%E9%83%A8%E6%99%BA%E8%83%BD%E6%89%8B%E6%9C%BA%E3%80%82%E5%9C%A8%E6%9C%AC%E5%BA%94%E7%94%A8%E4%B8%AD%EF%BC%8C%E6%A8%A1%E6%8B%9F%E4%BF%A1%E5%8F%B7%E8%A2%AB%E9%87%87%E6%A0%B7%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87%E5%A4%96%E9%83%A8%E8%93%9D%E7%89%99%E6%A8%A1%E5%9D%97%E4%BB%A5%E6%97%A0%E7%BA%BF%E6%96%B9%E5%BC%8F%E4%BC%A0%E8%BE%93%E5%88%B0%E6%99%BA%E8%83%BD%E6%89%8B%E6%9C%BA%E5%B9%B6%E6%98%BE%E7%A4%BA%E5%87%BA%E6%9D%A5%E3%80%82%E5%AE%8C%E6%95%B4%E7%9A%84%20CodeWarrior%20C%20%E4%BB%A3%E7%A0%81%E5%92%8C%20MIT%20App%20Inventor%20%E4%BB%A3%E7%A0%81%E5%8F%AF%E5%9C%A8%20.zip%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%89%BE%E5%88%B0%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22font-size%3A%2014pt%3B%22%3E%E7%B3%BB%E7%BB%9F%E7%BB%93%E6%9E%84%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CA%20href%3D%22https%3A%2F%2Flh6.googleusercontent.com%2Fa4aZNYoSta761nJ-luhJHHQcU6yH9IEwUeCET45L7l7n-rGNoAe_XXxHr_1Hep6qlmxQeQJmV1TF6T9Rlg0beEvTe_yVrFjNiEuC_UFtOZHtgJFZ5exMeKa2jKwvvL8aJGmMmXY%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22jive-image%22%20height%3D%22231px%3B%22%20src%3D%22https%3A%2F%2Flh6.googleusercontent.com%2Fa4aZNYoSta761nJ-luhJHHQcU6yH9IEwUeCET45L7l7n-rGNoAe_XXxHr_1Hep6qlmxQeQJmV1TF6T9Rlg0beEvTe_yVrFjNiEuC_UFtOZHtgJFZ5exMeKa2jKwvvL8aJGmMmXY%22%20style%3D%22border-style%3A%20none%3B%22%20width%3D%22624px%3B%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%3CSTRONG%3ESysTick%E6%A8%A1%E5%9D%97%EF%BC%9A%3C%2FSTRONG%3E%E5%AE%9A%E6%9C%9F%E8%A7%A6%E5%8F%91ADC%E8%BD%AC%E6%8D%A2%E5%92%8CUART%E4%BC%A0%E8%BE%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%3CSTRONG%3EADC%E6%A8%A1%E5%9D%97%3C%2FSTRONG%3E%EF%BC%9A%E5%AF%B9%E6%A8%A1%E6%8B%9F%E4%BF%A1%E5%8F%B7%E8%BF%9B%E8%A1%8C%E9%87%87%E6%A0%B7%E5%B9%B6%E7%AE%A1%E7%90%86ADC%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%3CSTRONG%3EUART%E6%A8%A1%E5%9D%97%EF%BC%9A%3C%2FSTRONG%3E%E7%AE%A1%E7%90%86UART%E8%BE%93%E5%87%BA%E7%BC%93%E5%86%B2%E5%8C%BA%E5%B9%B6%E4%BC%A0%E8%BE%93%E6%95%B0%E5%AD%97%E5%8C%96%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%3CSTRONG%3E%E8%93%9D%E7%89%99%E6%A8%A1%E5%9D%97%EF%BC%9A%3C%2FSTRONG%3E%E8%BF%9E%E6%8E%A5%E5%90%8E%EF%BC%8C%E4%BB%A5%E6%97%A0%E7%BA%BF%E6%96%B9%E5%BC%8F%E4%BC%A0%E8%BE%93%E6%9D%A5%E8%87%AA%20UART%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%3CSTRONG%3E%E6%99%BA%E8%83%BD%E6%89%8B%E6%9C%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9A%3C%2FSTRONG%3E%E5%A4%84%E7%90%86%E8%93%9D%E7%89%99%E8%BF%9E%E6%8E%A5%E3%80%81%E6%8E%A5%E6%94%B6%E6%95%B0%E5%AD%97%E5%8C%96%E6%95%B0%E6%8D%AE%E5%B9%B6%E7%AE%A1%E7%90%86%E6%98%BE%E7%A4%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3E%E8%BD%AF%E4%BB%B6%E7%BB%93%E6%9E%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E8%AF%BE%E7%A8%8B%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BC%9A%E4%B8%BA%E5%AD%A6%E7%94%9F%E6%8F%90%E4%BE%9B%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E6%A8%A1%E6%9D%BF%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%BB%96%E4%BB%AC%E8%83%BD%E5%A4%9F%E8%BD%BB%E6%9D%BE%E6%9E%84%E5%BB%BA%E4%B8%80%E4%B8%AA%E7%AE%80%E6%B4%81%E6%98%93%E7%94%A8%E7%9A%84%E7%A8%8B%E5%BA%8F%E7%BB%93%E6%9E%84%E3%80%82%E6%A8%A1%E6%9D%BF%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%E6%98%AF%E5%9C%A8%20Processor%20Expert%20%E7%9A%84%E5%B8%AE%E5%8A%A9%E4%B8%8B%E6%9E%84%E5%BB%BA%E7%9A%84%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%AD%A6%E7%94%9F%E7%A8%8D%E5%90%8E%E8%83%BD%E5%A4%9F%E7%90%86%E8%A7%A3%E5%85%B6%E7%BB%93%E6%9E%84%E5%92%8C%E5%B1%80%E9%99%90%E6%80%A7%EF%BC%8C%E5%B9%B6%E9%A1%BA%E5%88%A9%E8%BF%87%E6%B8%A1%E5%88%B0%E8%BF%99%E4%B8%AA%E6%96%B0%E5%B7%A5%E5%85%B7%E3%80%82%E6%88%91%E4%BB%AC%E5%9B%B4%E7%BB%95%E8%BF%99%E6%AE%B5%E8%87%AA%E5%8A%A8%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E6%9E%84%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%8C%85%E8%A3%85%E5%99%A8%EF%BC%8C%E5%B9%B6%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%20%E5%9C%A8%E9%A1%B9%E7%9B%AE%E5%BC%80%E5%A7%8B%E6%97%B6%E4%BD%BF%E7%94%A8%20%E7%94%9F%E6%88%90%E7%9A%84%E5%87%BD%E6%95%B0%20void%20__LDM_init%20(void)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3E%20%E3%80%82%E8%AF%A5%E5%87%BD%E6%95%B0%E4%B8%BB%E8%A6%81%E9%85%8D%E7%BD%AE%E4%B8%8E%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E7%9B%B8%E5%85%B3%E7%9A%84%E5%86%85%E9%83%A8%E5%A4%84%E7%90%86%E5%99%A8%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E8%AF%A5%E9%A1%B9%E7%9B%AE%E7%94%B1%E6%AF%8F%E4%B8%AA%E7%A1%AC%E4%BB%B6%E5%92%8C%E8%BD%AF%E4%BB%B6%E6%A8%A1%E5%9D%97%E7%9A%84%E5%8D%95%E7%8B%AC%E6%96%87%E4%BB%B6%E7%BB%84%E6%88%90%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20text-align%3A%20justify%3B%22%3E%E8%AF%A5%E6%A8%A1%E6%9D%BF%E7%94%B1%E5%9B%9B%E4%B8%AA%E6%96%87%E4%BB%B6%E7%BB%84%E6%88%90%EF%BC%9ALDM.c%2Fh%E3%80%81main.c%20%E5%92%8C%20misc.h%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20text-align%3A%20justify%3B%22%3E%E8%AF%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BD%8D%E4%BA%8E%EF%BC%9AApp.c%2Fh%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20text-align%3A%20justify%3B%22%3ERTI%E3%80%81ADC%E3%80%81UART%E3%80%81LED%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%AE%9A%E4%B9%89%E5%9C%A8%EF%BC%9ARTI.c%2Fh%E3%80%81adc.c%2Fh%E3%80%81uart.c%2Fh%20%E5%92%8C%20LED.c%2Fh%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E5%9F%BA%E6%9C%AC%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%BB%93%E6%9E%84%E5%8C%85%E5%90%AB%E4%B8%80%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3Evoid%20DRV_init(void)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%E3%80%81%E4%B8%80%E7%BB%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3Evoid%20DRV_%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3Ex%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3E_ISR(void)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E3%80%81%E4%B8%80%E7%BB%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3Evoid%20DRV_%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3Ex%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3E_PISR(void)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E5%91%A8%E6%9C%9F%E6%80%A7%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E4%BB%A5%E5%8F%8A%E4%B8%80%E7%BB%84%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3Evoid%20DRV_%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3Ex%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E6%9C%8D%E5%8A%A1%E5%87%BD%E6%95%B0%E3%80%82%E5%8F%AA%E6%9C%89%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%E6%98%AF%E5%BF%85%E9%9C%80%E7%9A%84%EF%BC%8C%E5%85%B6%E4%BB%96%E5%87%BD%E6%95%B0%E6%98%AF%E5%8F%AF%E9%80%89%E7%9A%84%EF%BC%8C%E5%8F%96%E5%86%B3%E4%BA%8E%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E7%94%A8%E9%80%94%E3%80%82%E6%9C%8D%E5%8A%A1%E5%87%BD%E6%95%B0%E6%98%AF%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B9%8B%E9%97%B4%E7%9A%84%E6%8E%A5%E5%8F%A3%EF%BC%8C%E4%B8%8D%E4%B8%80%E5%AE%9A%E8%AE%BF%E9%97%AE%E4%BB%BB%E4%BD%95%E5%BA%95%E5%B1%82%E7%A1%AC%E4%BB%B6%E3%80%82%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%AD%A4%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%BB%93%E6%9E%84%E5%8F%AF%E4%BB%A5%E5%B5%8C%E5%A5%97%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%A0%B9%E6%9C%AC%E4%B8%8D%E5%A4%84%E7%90%86%E4%BB%BB%E4%BD%95%E7%A1%AC%E4%BB%B6%E3%80%82%E5%BD%93%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%87%BD%E6%95%B0%E7%A1%AE%E5%AE%9E%E8%AE%BF%E9%97%AE%E7%A1%AC%E4%BB%B6%E6%97%B6%EF%BC%8C%E5%BB%BA%E8%AE%AE%E8%BF%9B%E4%B8%80%E6%AD%A5%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%E6%8A%BD%E8%B1%A1%E5%B1%82%E6%9D%A5%E6%8F%90%E9%AB%98%E7%94%9F%E4%BA%A7%E5%8A%9B%E5%92%8C%E5%8F%AF%E7%A7%BB%E6%A4%8D%E6%80%A7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2014pt%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3E%E7%B3%BB%E7%BB%9F%E6%91%98%E5%BD%95%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E4%BD%9C%E4%B8%BA%E9%A9%B1%E5%8A%A8%E5%99%A8%E7%BB%93%E6%9E%84%E7%9A%84%E7%A4%BA%E4%BE%8B%EF%BC%8CLED%E9%A9%B1%E5%8A%A8%E5%99%A8%E6%8F%8F%E8%BF%B0%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3Einit%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3Evoid%20LED_init%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%20(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3EISR%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3EN%2FA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3EPISR%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3Evoid%20LED_PISR%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%20(void)%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3E%E6%9C%8D%E5%8A%A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E6%97%A0%E6%95%88LED_write%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%EF%BC%88color_t%20%E9%A2%9C%E8%89%B2%EF%BC%8Cbool%20%E5%80%BC%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3Evoid%20LED_set%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%20(color_t%20color)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E6%97%A0%E6%95%88LED_%E6%B8%85%E9%99%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%EF%BC%88color_t%20%E9%A2%9C%E8%89%B2%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3Evoid%20LED_toggle%20(color_t%20color)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E6%95%B4%E4%B8%AA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%83%BD%E6%98%AF%E4%B8%AD%E6%96%AD%E9%A9%B1%E5%8A%A8%E7%9A%84%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%8F%AA%E9%9C%80%E8%A6%81%E5%88%9D%E5%A7%8B%E5%8C%96%E5%B9%B6%E4%B8%94%E8%BF%90%E8%A1%8C%E5%BE%AA%E7%8E%AF%E4%B8%BA%E7%A9%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3Evoid%20App_init(void)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3ELED%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%2F%2F%20LED%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3EUART_%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%2F%2F%20UART%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3Eadc_init()%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%2F%2F%20ADC%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3ERTI_init()%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%2F%2F%20RTI%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3Evoid%20App_run(void)%20%7B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E7%A1%AC%E4%BB%B6%E4%B8%AD%E6%96%AD%E4%B8%8D%E4%BC%9A%E5%9C%A8%E5%85%B6%E7%89%B9%E5%AE%9A%E7%9A%84%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%A4%84%E7%90%86%EF%BC%8C%E8%80%8C%E6%98%AF%E6%8F%90%E4%BA%A4%E7%BB%99%E5%A4%96%E9%83%A8%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BB%A5%E6%8F%90%E9%AB%98%E5%8F%AF%E8%AF%BB%E6%80%A7%E5%92%8C%E7%BB%84%E7%BB%87%E6%80%A7%E3%80%82SysTick%20%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E7%94%B1%E4%B8%80%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3EISR%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E5%92%8C%E4%B8%80%E4%B8%AA%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%20font-weight%3A%20bold%3B%22%3EService%3C%2FSPAN%3E%E7%BB%84%E6%88%90%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3EISR_t%20SysTick_Handler%EF%BC%88%E6%97%A0%E6%95%88%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3ELED_isr%20%E4%BB%A3%E7%A0%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3EADC_conv%E4%BB%A3%E7%A0%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%E6%99%BA%E8%83%BD%E6%89%8B%E6%9C%BA%E7%AB%AF%E7%9A%84%E4%BB%A3%E7%A0%81%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Flh6.googleusercontent.com%2FZnABsjdfW2rowI59uYxWqOQPnygwh7tS0jX-BIxMBiuzcleU0CFzYKzPxL_gBeYSmpYw6iyz2ft4BvBheDje1_7aMHBa6e3Zhl2UepsVumqBomRo6R1EWx0FDwn-iNWKwGqX7DM%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22jive-image%22%20height%3D%22301px%3B%22%20src%3D%22https%3A%2F%2Flh6.googleusercontent.com%2FZnABsjdfW2rowI59uYxWqOQPnygwh7tS0jX-BIxMBiuzcleU0CFzYKzPxL_gBeYSmpYw6iyz2ft4BvBheDje1_7aMHBa6e3Zhl2UepsVumqBomRo6R1EWx0FDwn-iNWKwGqX7DM%22%20style%3D%22border-style%3A%20none%3B%22%20width%3D%22605px%3B%22%20%2F%3E%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%20%E6%9C%80%E5%90%8E%EF%BC%8C%E6%9D%A5%E4%B8%80%E5%BC%A0%E7%BB%93%E6%9E%9C%E6%88%AA%E5%9B%BE%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Flh5.googleusercontent.com%2Fg4BWVhRv3KlsY0PLYNm222sThHy4k982N-3jLtFq2hPtYCE2cYcwhw8017TeXuI5lomaQb4Emy3cnSg-wkSu3OxHJYPsFSfwGPx1GQ-GrKLDR4WA7qwMhwDCgJKjtFdeJar-N4g%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22jive-image%22%20height%3D%22239px%3B%22%20src%3D%22https%3A%2F%2Flh5.googleusercontent.com%2Fg4BWVhRv3KlsY0PLYNm222sThHy4k982N-3jLtFq2hPtYCE2cYcwhw8017TeXuI5lomaQb4Emy3cnSg-wkSu3OxHJYPsFSfwGPx1GQ-GrKLDR4WA7qwMhwDCgJKjtFdeJar-N4g%22%20style%3D%22border-style%3A%20none%3B%22%20width%3D%22185px%3B%22%20%2F%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2013px%3B%20font-family%3A%20Arial%3B%20color%3A%20%23222222%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20dir%3D%22ltr%22%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3E%E5%8E%9F%E5%A7%8B%E9%99%84%E4%BB%B6%E5%B7%B2%E7%A7%BB%E8%87%B3%EF%BC%9A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339530%22%20target%3D%22_blank%22%3E-ADC-bluetooth-TP6.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1129275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%AD%A6%E7%94%9F%E9%A1%B9%E7%9B%AE%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎05-09-2015 08:51 AM
更新人:
