Hi:
Before the compile time there is no problem can download the program, there is no change called home. Compiled this morning, there was an error, even if the software was reinstalled. what should I do?Thank you very much.
Hi Wang,
From your description. I think you should use special edition license which code size limitation is 32K.
now your program code size is 37480bytes that is over your CW code size limitation, so it produces error.
To remove your error you need upgrade your license, but it is not free.
here is CW reference guide which includes the price list:
http://www.nxp.com/assets/documents/data/en/fact-sheets/950-00437.pdf
if you have any specific question on this related, please let me know.
Jennie Zhang
