A suitable pressure sensor for e-cigarette application for sensing air flow
shai_b
Senior Contributor II
Hello Team,
Could you please suggest a suiatlabe pressure sensor for sensing the airflow in the E-CIG application?
the minimum requirements as follow:
  • Pressure range – the main issue is to indicate the human inhale, which could be used in the e-cigarette
  • Temp range 0-40 deg. C
  • Supply voltage 3.3-5VDC
Looking forward to your recommendations, Thanks a lot.
Shai
reyes
I don’t have experience with the application of e-cigarettes, but I’m assuming for this application…
  1. The pressure range is small around 2 to 4 kPa (please correct me if I’m wrong),
  2. Since it is for human inhale you need to measure negative pressure,
  3. And I would personally use a device that can handle both negative and positive pressure mainly for protection of the device (in case someone exhale in the e-cigarrate).
Based on these points and your requirements, I would like to recommend you the MPXV7002DP: https://www.nxp.com/docs/en/data-sheet/MPXV7002.pdf
Jose
reyes
Jose
shai_b
Dear @reyes,
Thank you a lot for your inputs, Can you please suggest a suitable pressure sensor with a digital output?
Could I offer him the MPL3115A2 as an option for a pressure sensor with a digital output? Thanks in advance.
Kind regards,
Shai
reyes
Correct, MPL3115A2 is a digital ouput solution.
And other digital output options are:
FXPQ3115: https://www.nxp.com/docs/en/data-sheet/FXPQ3115BV.pdf
FXPS7115: https://www.nxp.com/docs/en/data-sheet/FXPS7115D4.pdf
Jose
shai_b
@reyes,
I've noticed that there is no digital pressure sensor that can measure negative pressure.
Since as far as I know the physics of breathing, the inhales pressure is around –4 mm Hg to -10 mm Hg (negative) which is around 0.5 – 1.5 kPa (negative) but the MPL3115 starts from +20 kPa (up to 110 kPa).
Could you please suggest the right implementation technic to detect human inhale with MPL3115?
Thanks in advance
Kind regards,
Shai
reyes
Hi Shai,
Unfortunately, it would not be possible to measure pressure below +20kPa using the MPL3115A2
For this case, I would return back to my initial recommendation, the MPXV7002 which can measure negative and positive pressure in the range from -2kPa to +2kPa.
This is an analog output sensor, so you would need to use an external ADC to convert the analog signal to a digital signal.
MPXV7002 datasheet: https://www.nxp.com/docs/en/data-sheet/MPXV7002.pdf
Jose
shai_b
Got it, Thanks.
KR,
Shai
%3CLINGO-SUB%20id%3D%22lingo-sub-1268862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EA%20suitable%20pressure%20sensor%20for%20e-cigarette%20application%20for%20sensing%20air%20flow%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1268862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Team%2C%3C%2FP%3E%3CP%3ECould%20you%20please%20suggest%20a%20suiatlabe%20pressure%20sensor%20for%20sensing%20the%20airflow%20in%20the%20E-CIG%20application%3F%3C%2FP%3E%3CP%3Ethe%20minimum%20requirements%20as%20follow%3A%3C%2FP%3E%3CUL%3E%3CLI%3EPressure%20range%20%E2%80%93%20the%20main%20issue%20is%20to%20indicate%20the%20human%20inhale%2C%20which%20could%20be%20used%20in%20the%20e-cigarette%3C%2FLI%3E%3CLI%3ETemp%20range%200-40%20deg.%20C%26nbsp%3B%3C%2FLI%3E%3CLI%3ESupply%20voltage%203.3-5VDC%3C%2FLI%3E%3C%2FUL%3E%3CP%3ELooking%20forward%20to%20your%20recommendations%2C%20Thanks%20a%20lot.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EShai%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1272765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20A%20suitable%20pressure%20sensor%20for%20e-cigarette%20application%20for%20sensing%20air%20flow%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1272765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGot%20it%2C%20Thanks.%3C%2FP%3E%3CP%3EKR%2C%3C%2FP%3E%3CP%3EShai%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1271924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20A%20suitable%20pressure%20sensor%20for%20e-cigarette%20application%20for%20sensing%20air%20flow%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1271924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Shai%2C%3C%2FP%3E%0A%3CP%3EUnfortunately%2C%20it%20would%20not%20be%20possible%20to%20measure%20pressure%20below%20%2B20kPa%20using%20the%20MPL3115A2%3C%2FP%3E%0A%3CP%3EFor%20this%20case%2C%20I%20would%20return%20back%20to%20my%20initial%20recommendation%2C%20the%20MPXV7002%20which%20can%20measure%20negative%20and%20positive%20pressure%20in%20the%20range%20from%20-2kPa%20to%20%2B2kPa.%3C%2FP%3E%0A%3CP%3EThis%20is%20an%20analog%20output%20sensor%2C%20so%20you%20would%20need%20to%20use%20an%20external%20ADC%20to%20convert%20the%20analog%20signal%20to%20a%20digital%20signal.%3C%2FP%3E%0A%3CP%3EMPXV7002%20datasheet%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FMPXV7002.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FMPXV7002.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EJose%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1271434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20A%20suitable%20pressure%20sensor%20for%20e-cigarette%20application%20for%20sensing%20air%20flow%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1271434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F35448%22%20target%3D%22_blank%22%3E%40reyes%3C%2FA%3E%2C%3C%2FP%3E%3CP%3EI've%20noticed%20that%20there%20is%20no%20digital%20pressure%20sensor%20that%20can%20measure%20negative%20pressure.%3C%2FP%3E%3CP%3ESince%20as%20far%20as%20I%20know%20the%20physics%20of%20breathing%2C%20the%20inhales%20pressure%20is%20around%20%E2%80%934%20mm%20Hg%20to%20-10%20mm%20Hg%20(negative)%20which%20is%20around%200.5%20%E2%80%93%201.5%20kPa%20(negative)%20but%20the%20MPL3115%20starts%20from%20%2B20%20kPa%20(up%20to%20110%20kPa).%3C%2FP%3E%3CP%3ECould%20you%20please%20suggest%20the%20right%20implementation%20technic%20to%20detect%20human%20inhale%20with%20MPL3115%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance%3CBR%20%2F%3EKind%20regards%2C%3CBR%20%2F%3EShai%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1271347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20A%20suitable%20pressure%20sensor%20for%20e-cigarette%20application%20for%20sensing%20air%20flow%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1271347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3ECorrect%2C%20MPL3115A2%20is%20a%20digital%20ouput%20solution.%3C%2FP%3E%0A%3CP%3EAnd%20other%20digital%20output%20options%20are%3A%3C%2FP%3E%0A%3CP%3EFXPQ3115%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FFXPQ3115BV.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FFXPQ3115BV.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EFXPS7115%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FFXPS7115D4.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FFXPS7115D4.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EJose%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1271111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20A%20suitable%20pressure%20sensor%20for%20e-cigarette%20application%20for%20sensing%20air%20flow%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1271111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F35448%22%20target%3D%22_blank%22%3E%40reyes%3C%2FA%3E%2C%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20a%20lot%20for%20your%20inputs%2C%20Can%26nbsp%3Byou%20please%20suggest%20a%20suitable%20pressure%20sensor%20with%20a%20digital%20output%3F%3C%2FP%3E%3CP%3ECould%20I%20offer%20him%20the%20MPL3115A2%20as%20an%26nbsp%3Boption%20for%20a%20pressure%20sensor%20with%20a%20digital%20output%3F%26nbsp%3BThanks%20in%20advance.%3C%2FP%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CP%3EShai%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1269068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20A%20suitable%20pressure%20sensor%20for%20e-cigarette%20application%20for%20sensing%20air%20flow%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1269068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EI%20don%E2%80%99t%20have%20experience%20with%20the%20application%20of%20e-cigarettes%2C%20but%20I%E2%80%99m%20assuming%20for%20this%20application%E2%80%A6%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EThe%20pressure%20range%20is%20small%20around%202%20to%204%20kPa%20(please%20correct%20me%20if%20I%E2%80%99m%20wrong)%2C%3C%2FLI%3E%0A%3CLI%3ESince%20it%20is%20for%20human%20inhale%20you%20need%20to%20measure%20negative%20pressure%2C%3C%2FLI%3E%0A%3CLI%3EAnd%20I%20would%20personally%20use%20a%20device%20that%20can%20handle%20both%20negative%20and%20positive%20pressure%20mainly%20for%20protection%20of%20the%20device%20(in%20case%20someone%20exhale%20in%20the%20e-cigarrate).%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBased%20on%20these%20points%20and%20your%20requirements%2C%20I%20would%20like%20to%20recommend%20you%20the%20MPXV7002DP%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FMPXV7002.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FMPXV7002.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EJose%3C%2FP%3E%3C%2FLINGO-BODY%3E
