8652 pinout orientation
petrus6432
Hi, I would like to be sure about MMA8652 mounting pinout. My sensor has a line and a "652 2YR" marking below.
Looking this, pin 1 is on the top left corner? Please refer to the attached image.
Thanks.
Tags (2)
TomasVaverka
Hi Pedro,
Yes, pin 1 is in the top left corner:
Square pad for pin 1, rounded pad for the other pins:
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
TomasVaverka
Hi Pedro,
Tomas
petrus6432
Thanks Tomas, one less thing to doubt.
