I am injecting the stack overflow error of S32K3XX MCU, and after successfully injection of error DebugMon_Handler exception triggering.
I have a query Related to recovering methods. during testing observed only After power on reset MCU is able to recover from Stack Overflow exception.
Please let me know is there any other methods of recovery.
Hello, I would also like to know more of how to mitigate this.
BR, Lee CirrusAircraft Engineer
HI Raj,
I have been discussing this query with our SW team and there is debate if such type exception handler as the cause of failure would be detected by lockstep, SCST or prevented for systematic fault.
Some exception handlers are tested as part of our SAF Schecks or SCST.
Can you tell me the strategy and safety requirement you are trying to achieve and I can refine the method we are using (or if we think it is necessary or not).
Antoine
Hi Raj, I just wanted to let you know I am still investigating this query with the SW team. Sorry for the delay, this is not a straightforward answer.
Antoine
Hi Raj12,
it may depend on the way you inject the stack overflow error. I would need a bit more details to understand how you are injecting the faults, and the reaction you are seeing.
Could you share pseudo code, or diagram.
