s32k324 standby mode and can wakeup
485件の閲覧回数
Prasad_330
hi
currently i am working on the S32k324 controller
I wanted to enable the standby mode and CAN wake up mode.
I tried to configure the CAN rx pin as wkup 10.
and also i am able to enter into stand by  mode but unable to wakeup.
There are some example of can wake up mode but i am not able to open the .mex file
I want some help in configuration plz help me.
8 返答(返信)
427件の閲覧回数
Prasad_330
Hi Julian_ArogonM,
Thanks for the reply,
I am facing the same problem with the example S32K3 Low Power Management AN and demos.
can you plz help me out.
422件の閲覧回数
Julián_AragónM
Hi @Prasad_330,
Make sure you are correctly flashing the projects:
You can use the following community posts as reference:
Julián
389件の閲覧回数
Prasad_330
Hi Julian_AragonM
All the above mentioned configuration are properly configured in my project
370件の閲覧回数
Julián_AragónM
Hi @Prasad_330,
Could you elaborate on the issue? Is it going into hard fault when stepping into the function? Could you debug step by step to see which line causes the problem?
325件の閲覧回数
Prasad_330
Hi Julian_AragonM,
I am configuring the PTB19 as the wake up and PTE10   as output which drives the LED
i am able to put the controller into the standby mode but i am not able to wake up it.
The Led will be turned ON after controller wakes up.
I am attaching the code.
Plz suggest me what is the right configuration
267件の閲覧回数
Julián_AragónM
Hi @Prasad_330,
I can see in your configuration that FAST_STANDBY is used. You can copy over the configurations from the S32K3 Low Power Management AN and demos (GPIO Wkup S32K324):
The value of McuDcmGprConfiguration.boot base address for Fast wake up must be same with the address of FastWkupBootVectorTable, so add a ".fastboot_vector" section in linker files:
You can configure the fast standby, or use normal Standby as in the example:
Julián
439件の閲覧回数
Prasad_330
Thanks  Julian_ArogonM,
I installed  RTD V2.0 and S32DS3.4 and started working on it .
I tried S32K324_GPIO_Wkup_S32DS_RTD_LLD_2_0_M7_0 example just to test, but is not coming out of
" Power_Ip_Init(&Power_Ip_HwIPsConfigPB)". I did not make any modification.
Can you plz help me.
461件の閲覧回数
Julián_AragónM
Hi @Prasad_330,
You can look into these examples: S32K3 Low Power Management AN and demos.
These examples are based on RTD V2.0 and S32DS3.4, so you need to install the corresponding software.
Julián
