s32k312 flexcan interrupt
fengba_360
Hello, I am implementing FlexCAN transmission and reception on an S32K312 using interrupts, but the data transmitted by the S32K312 does not match what I receive using a CAN card. Could you please advise me on possible reasons for this? Attached is an illustration of my configuration setup.微信图片_20240903112421.png微信图片_20240903112337.png微信图片_20240903112144.png微信图片_20240903112513.png
Senlent
Hi@fengba_360
1.first, the demo you send to me can build sucess cause missing some file. please double check it.
2.second, In your code, the “dummyData” array has not been modified, so the data in your screenshot is inconsistent with your code.
Senlent
Hi@fengba_360
Could you please provided your project so that we can help you find the root cause.
fengba_360
hello,The attachment is the project information. Please check it. I feel like I sent the address information. thanks。
Senlent
Hi@fengba_360
fengba_360
The CAN transmission is called in the following part of the code.
dummyData[8]={1,2,3,4,5,6,7,8}
Senlent
Hi@fengba_360
There is a problem with the usage of C pointer.
Please try to change the highlighted part below.
fengba_360
Thank you. I made a big mistake. I'm sorry.
fengba_360
Hello, no matter what data I fill in the dummy array, the data I receive through the CAN card is always the same (the CAN ID is correct, but the CAN data seems to be address information). The attachment is the latest successfully compiled code. It is consistent with the phenomenon I described.
