s32k144
s32k144
zhouqichen
hello,  S32K144 ADC0 Select channel8 When PTC0 is selected, Muxed in SIM will be enabled by default_ CHIPCTL, it will report an error when it is turned off. What is the reason.
danielmartynek
Hello @zhouqichen,
What error message do you get?
Can you elaborate?
Thank you,
BR, Daniel
zhouqichen
Hello, display
Description Resource Path Location Type
Selected value is in conflict with other configuration property 'ADC Interleave', conflict in configuration of ADC_Interleave bit-field of PORTC_PCR0 register. (Channel AMCs32k144 pin_mux/Channel 8 Processor Expert Problem
Selected value is in conflict with other configuration property 'Channel 8', conflict in configuration of ADC_Interleave bit-field of PORTC_PCR0 register. (ADC Interleave) AMCs32k144 pin_mux/ADC Interleave Processor Expert Problem
danielmartynek
Hi @zhouqichen,
I'm sorry but I still don't understand.
If it is an error message from Process Expert, can you share a screenshot of it?
Or can you attach the project so that I can reproduce it?
BR, Daniel
