s32ds-v3.4 debug s32k344 via PE
huangjia
Hi dears, i'm using s32ds-v3.4 to debug s32k344 via PE, but it report PE doesn't support the device. I've already update the PE firmware to the latest version. Is there anything i should check about?新建位图图像 (2).bmp新建位图图像 (3).bmp新建位图图像.bmp
Robin_Shen
Hi feihong,
The Multilink Universal Rev A you are using is causing this problem.
"USB Multilink FX RevA and Universal Rev A and B are based on legacy UF32 USB devices, which are no longer actively supported/validated by PEmicro under the latest plugins/software packages.
To get latest support user would need Multilink FX Rev C, Multilink Universal Rev C/D or Multilink ACP"
Robin
Robin_Shen
Hi feihong,
Robin
