hello.,sir.I have met a problem when installing S32DS 3.2.I have used the activation code to choose online activation at the first time but failed.Then,I unstalled it and reinstall it and the installation rolled back.The problems are listed in the pictures in detail.Thanks!
I have not seen this issue before.
Nevertheless you are using outdated version of S32DS v3.2 - which was more like prototype then production SW.
I recommend you to get version 3.5 or 3.4.
Peter
We will investigate the log you have shared.
However it looks like there is issue with access to flexera on your PC.
Do you install the S32DS as admin? Otherwise it wont work.
Could you ask your IT for help with installation as we expect the issue in linked to your PC settings.
Peter
