did not run without debugger
종찬박
Hi, I'm jongchan.
I'm trying to execute S32K without debugger.
I referred below link.
https://community.nxp.com/t5/S32K/S32K188-runs-with-debugger-but-not-witout/m-p/1205346/emcs_t/S2h8Z...
but I can't run my board after power reset.
How can I do for this problem?
Robin_Shen
Hi jongchan,
I know that you have define START_FROM_FLASH in Standard S32DS Assembler -> Preprocessor
IDE:
S32 Design Studio for S32 Platform
 - Version: 3.3
 - Build id: 200610
MCU:
S32K118
SDK:
Seems that you are using "SDK RTM v4.0.1".
Did you created project with "S32DS Application project" button?
Have you tried "S32DS Project from example" button (hello_world_s32k118) and does it works fine with and without debugger?
Would you please attached a test project here? So that I can check it.
Robin
Robin_Shen
Hi jongchan,
IDE:
 - Version: 3.3
 - Build id: 200610
MCU:
S32K118
SDK:
Robin
종찬박
Hi Robin,
Thanks. I am able to check my board run.
