S32K344 FLEXCAN
S32K344 FLEXCAN
wangjunxiao
hi~ i want to create a can project  using SW32K344_RTD_4_4_081_D2011,but when i config the components FlexCAN_43_1 there was no bitrate appeared
IN the S32K3 RTD TRAINNING - FLEXCAN PDF , the FlexCAN_43_1 has the bitrate .see the next picture
please tell me how to configur the can bitrate? thanks~
PetrS
seems you are using some older RTD version. Try to update your S32DS with some recent one.
I checked SW32K3_RTD_4_4_2_0_1_D2207 in S32DS3.4 and it gives bitrate calculation.
Anyway you can calculate bitrate as PE clock / Prescaler / (1+prop_seg+phaseseg1+phaseseg2).
BR, Petr
wangjunxiao
ok thankyou~
