S32K314 Linker script error
971件の閲覧回数
abhijith_r
I have created a FreeRTOS project for S32K314. I don't have the proper linker script for S32K314. So I used linker script of S32K312. But I can't use the total memory of S32K314 with this script. I have done some modification in this one, but that didn't works.Can someone share the linker script for S32K314.
Regards,Abhijith Raj
5 返答(返信)
954件の閲覧回数
VaneB
Hi @abhijith_r
Which IDE are you using?
951件の閲覧回数
abhijith_r
Hi @VaneB
I am using S32 design studio 3.5
948件の閲覧回数
VaneB
Hi @abhijith_r
You should be able to find the Linker files in the Project Settings folder of your project.
B.R.
VaneB
936件の閲覧回数
abhijith_r
Hi @VaneB ,
We have S32K312 and K344 example projects. When I try to use linker script of S32K312 it is working and when I modify the memory address it is crashing my firmware. But for S32K344 it is not working even without any modification.
タグ(1)
927件の閲覧回数
VaneB
Hi @abhijith_r
The Linker script to configure memory regions are generated when creating the project, whether using any SDK or not.
Could you tell me how you generated your project for S32K314 to try to replicate the problem?
