S32K1XX SDK EAR version and RTM version are different?
已解决
跳至解决方案
8,929 次查看
HeeSu
Hi, I'm student who is developing with S32K148EVB-176Q.
I'm tryting to porting Erika-Enterprise on target board but there might some missing file on S32K1 SDK.
There are couple error in build processing.
The first is about the gcc flag error. However, it was solved by itself through file modification.
Second one is about sdk file. In Makefile, there is require some file like clock_manager.c .
But there is no file like clock_manger.c in S32K1 SDK.
I Downloaded S32K SDK 4.0.3 RTM version from NXP homepage and 3.0.3 RTM version from S32DS for ARM IDE.
But both one not working.
Should I use SDK of EAR version? but i can't find file about EAR version.
Is there any solution this problem?
Best,
1 解答
8,902 次查看
Senlent
Hi@HeeSu
Thank you for your information,
But the IDE you use is not provided by NXP, and we cannot provide technical support, which is beyond our ability to serve.
For RTM 4.0.3, try S32 Design Studio for S32 Platform V3.4
https://www.nxp.com/design/software/development-software/s32-design-studio-ide/s32-design-studio-for...
在原帖中查看解决方案
8 回复数
8,913 次查看
Senlent
Hi@HeeSu
You must confirm the IDE and SDK version used by your demo, otherwise it will cause compilation errors
You can find EAR SDK versions on this page,
8,906 次查看
HeeSu
Hi @Senlent
Thank you for your help.
I'm using the IDE eclipse(Photon Release (4.8.0) with RT-Druid (3.0.1))  and SDK is S32_SDK_S32K1xx_RTM_4.0.3.
My GNU arm compiler is version 10.3.
These are my developing envrionment. And I did not any update for board after i get the borad.
Best,
8,903 次查看
Senlent
Hi@HeeSu
8,896 次查看
HeeSu
Hi @Senlent
Then, Can I porting OSEK OS through S32 Design Studio?
Best,
8,891 次查看
Senlent
Hi@HeeSu
I think this should be possible, but we will not provide technical support for third-party porting
8,812 次查看
Senlent
Hi@HeeSu
yes, these files are automatically  generated by IDE.
8,875 次查看
HeeSu
Hi @Senlent
Can I ask one more thing about SDK?
Does the S32K1 RTM 4.0.3 SDK 'platfrom/drivers/src' folder generally include clock/clock_manager.c, power/S32K1xx/power_pmc_hw_access.c, and power/S32K1xx/power_rmc_hw_acces
Best,
8,888 次查看
HeeSu
Thank you for your help. Have a nice day!
Best,
