S32K144 PortPin PCR value
1,584 次查看
Oliverc
I am trying to configure an S32K144EVB board. I have followed this guide to create an example project. My problem is that I do not understand how the PortPin PCR value is determined. I have looked in the RTD_PORT_UM.pdf document for how to calculate this but I don't understand how to get the number 96 for PortPin PCR using these instructions when trying to set up the blue LED pin. The instructions also reference "PortPin MSCR", which doesn't appear in the software, leading me to believe the documentation may be outdated.
Thank you in advance
标记 (1)
1,575 次查看
Senlent
Hi@Oliverc
you can find these infos in S32K-RM
https://www.nxp.com/search?keyword=S32K1xx%2520MCU%2520Family%2520-%2520Reference%2520Manual%2520&st...
 I attached it for your reference:
and MSCR register exists in S32K3 series only,
