S32K DESIGN STUDIO CALL STACK
1,964 次查看
hajianik
Senior Contributor I
I'm using S32k Design Studio and my target is  S32K144EVB. I can use the debugger's (open SDA) most of the features however the call stack is always blank. when  I pause or a break point is triggered , it's always blank.
What do I need to do to fix this?
1,821 次查看
martin_kovar
could you please post here some screen of the feature you mean?
Martin
1,821 次查看
hajianik
I can run some GDB command like  Back trace, frame. But the call stack is always blank
Koorosh Hajiani
