Regarding BMS SDK for S32K344
1,450件の閲覧回数
tetsuya_nakamur
The customer is having trouble incorporating the BMS SDK into the IDE environment.
I have attached the contents, so please check it.
Please let me know the cause and solution.
I'm sorry, but please answer by 8/23.
3 返答(返信)
1,408件の閲覧回数
diazmarin09
Hello tetsuya_nakamur,
I hope all is great with you. Thank you for using the NXP communities.
As mentioned on the case created, I do recommend using the HVBMS Software Installation Guide as a reference.
Please go to Software section and click on Automotive Software Package manager from the link below:
https://www.nxp.com/design/designs/hvbms-reference-design-bundle-using-etpl:RD-HVBMSCTBUN
I hope this information helps.
David
1,355件の閲覧回数
tetsuya_nakamur
Dear David-san,
It does not solve the problem yet.
But, the customer downloaded the material you answered and followed the steps in "5.1.2.3 BMS Software Development Kit", but SW32K3_BMS_SDK_4.4_0.9.0_D2210.exe was already installed.
Also, I found 1.0.0 (D2304), which is newer than version 0.9.0 (D2210),I uninstalled 0.9.0 and installed 1.0.0,
the result was the same (Create a new project: BMS SDK is not displayed in the SDK selection column).
[Question]
1.After all, which of the following is the correct way to install the BMU SDK?
 a) Installer (SW32K3_BMS_SDK_4.4_1.0.0_D2304.exe)
 b) S32DS Help-Install new software menu (SW32K3_BMS_SDK_4.4_1.0.0_updatesite_2304.zip)
2.Also, please answer any other solution.
AVNET
Tetsuya Nakamura
1,343件の閲覧回数
diazmarin09
In response to my request for further information, our specialist has concluded that we need the following information to better understand the situation.
  1. Are you using a HVBMS bundle board?
  2. What example are you trying to run?
  3. Have you run the HvBms400_775_772_TPL_Bring_Up  example?
You may review the last reply at the case created for further information.
David
