RappId Bootloader S32K144, and use of LPUART1 in Appl.
christofferjärl
I have the RappId Bootloader flashed to my S32K144 and successfully flashing appl. by Serial.
But  I,m having trouble initializing LPUART1 in my application.
Regardless what I try to do I cant change the baud rate from 57600bps.
Finally I realized that the LPUART1 gets initialized in bootloader, right?
I have tried to set, and then clear, the Reset in GLOBAL reg. and then reinitialize LPUART1, -but don't work.
Getting stuck with 57600 even when i try to set 9600 (LPUART1->BAUD = 0x0F000034;)
Waht am I doing wrong?
And also, are there more modules/peripherals/clocks initialized in the bootloader that I should know about?
Thank you!
/Chris
Tags (2)
christofferjärl
I believe I found the problem.
My setup code in application reinitialize the clock source for LPUART1 as (copied from "clocks_and_modes.c"):
PCC->PCCn[PCC_LPUART1_INDEX] |= PCC_PCCn_PCS(0b001)
The "or" operator cause it to not take affect I intended, when it were already initialized once by Bootloader.
But anyhow, some more info of what is initialized and how in RappId Bootloader would be very good!
