Merging code of Processor Expert and S32DS Tool chain SDK Code
1,058 次查看
Nibesh
Hello
Can we merge Processor Expert Code and SDK Code, how to convert ?
Is there is any Bootloader Code made using Processor Expert for AN12218SW for S32K148EVB?
Nibesh
2 回复数
1,032 次查看
Senlent
Hi@Nibesh
The Bootloader code in AN12218SW is based on bare metal and cannot be directly converted into Processor Expert format.
However, the AN12218SW project is not very complicated. You can try to re-create it from scratch using the SDK, but this will take a lot of your time.
1,018 次查看
Nibesh
Thank you very much @Senlent.
I will follow your point.
