KEIL S32K144 SDK Question
walker_xiao
Hello
The compiler I am using is KEIL MDK. When using the S32K144 SDK, some .h files can't find the file. I didn't find any reason. I don't know if you can answer it for me.
danielmartynek
I'm not familiar with KEIL IDE, I would recommend contacting KEIL support.
As far as I know, the SDK does not support the IDE.
Please refer to the SDK release notes located in the S32DS installation folder, for example:
\NXP\S32DS_ARM_v2018.R1\S32DS\S32SDK_S32K1xx_BETA_2.9.2\S32SDK_for_S32K1xx_BETA_2.9.2_ReleaseNotes.pdf
Did you generate all the required files with Processor Expert in the S32 Design Studio?
