Hello everyone,
I am using the S32k146 EVB I am using the Example "lin_master_s32k146" from the "S32K1xx RTM SDK v3.0.0 Example Projects". For monitoring Vector is being used, to see the traces of the communication.
Now I want to "modify" this example code to send out a diagnostic session Command.
I am not able to do this, i tried several things.
In the Example the 2 Buttons are used to enter deep sleep and wake up again.
I want to use these buttons to send out different diagnostic session commands.
(I think this is the easiest way to understand the diagnostic session)
A easy example on how to use these Lin commands would be great.
Or how do I have to modify the Code to send out these diagnostic session commands?
PS: Attached is the "Lin_master_s32k146" without any changes
Hello Hung,
thanks for your answer!
The values shown in your screenshot, were the default values for me so I did not have to change them. I used your recommended function, but it didn't work either. I expect changes in the schedule Table shown in my screenshot, but in there nothing changes. What did I miss?
Thanks for your time and effort,
Raphael
