Change projet from S32K142 to S32K144
Search instead for
MaxSKDRN
Hello
I need to change my SOC from S32K142 to S32K144.
How should I change the settings of my project done for S32K142 to be build for S32K144 ?
Thanks for your help
PetrS
you did not specify what is the project based from. For example for SDK based one in S32DS2.2 you can follow steps in https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-Change-the-CPU-Derivative-in-an-...
Otherwise it can be recommended to create new project and manually copy user code, I think.
BR, Petr
