CanNot Open EBTresos(24.0.1)
3,801 次查看
biyangdong
I can't open the EB tresos(24.0.1) suddenly these days,it returned java was started but returned wxit code = -805306369.
my mcal version is S32K14X_MCAL4_3_RTM_HF4_1_0_1.
I saw the same issue in this forums and the reply is need requested a hotfix, and my mail accont is: bydong@iflytek.com。
please help me to solve this problem,thak you very much.
17 回复数
3,571 次查看
namnguyenviet
@evanGOGO Which EB tresos version you're facing the problem?
Best  Regards,
Nam
3,564 次查看
evanGOGO
After entering EB for a long time, the following questions are also prompted.
3,565 次查看
evanGOGO
Thank you for your reply. The current problems are slightly different. Now EB can only be opened for a long time (more than ten minutes). If it is not operated in the middle, EB will not report an error. If the MCAL is generated through DaVinci integrated EB, it will take longer. The current environment has been used for several months, and this problem suddenly appears.
3,558 次查看
namnguyenviet
We can provide you a hot-fix for this case, however to be honest I'm not sure whether that hot-fix can fix your problem. What's your NXP account?
1,310 次查看
Jack527
3,542 次查看
evanGOGO
wx601056818@outlook.com,Thank you.
3,516 次查看
namnguyenviet
Hello @evanGOGO,
Your access has been granted. Please try in your site.
Nam
3,495 次查看
evanGOGO
There is no problem opening the software, but there are new problems. Prompt: there is no valid license, but I deleted the old one and added it again. Is there a solution to this problem? We look forward to your reply.
3,488 次查看
namnguyenviet
Hello @evanGOGO,
I see you're using license administrator 1.3.0. Can you try to upgrade to 1.4.0 or higher?
Nam
3,453 次查看
evanGOGO
Upgrade to 1.4 will be fine. Thank you very much!
3,792 次查看
namnguyenviet
Your request has been success. Please check in your SW Licensing and Account.
BR,
Nam
3,786 次查看
biyangdong
thanks,i have got the HotFix in my account,but i am confused that how to deal with it,just replace that .jar files in the tresos install path will be ok? can you tell me more details about it, thank you ,best regards.
3,770 次查看
namnguyenviet
Hello @biyangdong,
Please apply the following steps:
Unzip attached file (dreisoft.tresos.launcher2.jar_EB_tresos_Studio_V24.0.1_FNP11.16.5.1_HOTFIX.zip) to "<EB tresos V24.0.1 installation path>"
Open a CMD and change to "<EB tresos V24.0.1 installation path>\bin" folder
Call "tresos_gui.exe" with "-clean" option ("tresos_gui -clean")
3,763 次查看
biyangdong
thank you very much,i have resolved this problem.
3,793 次查看
namnguyenviet
We have received your request and will let you know once it's finished.
BR,
Nam
3,801 次查看
biyangdong
3,585 次查看
evanGOGO
I have the same problem as you. Can you tell me how to solve it? Thank you!
