Can put the srec file into ld file
zhanghw
Can I put the "srec" file into the "ld" file without converting it into a "bin" file like this:微信截图_20200320163459.png
Alexis_A
Hi ,
Unfortunately, checking with other formats (hex, srec or symbolsrec) and it looks like it doesn't support other formats outside the binary format.
Sorry for the inconveniences this may cause you.
Alexis Andalon
