CAN BUS
CAN BUS
ZzzzzZzzzz
How to synchronized the can bus of S32K118? I use example of can_pal_s32k118,but ESR1 registers  indicating that Flexcan is not  synchronized to the CAN bus .
PetrS
could be pin setup, or transceiver issue (not active). FlexCAN must see 1 on RX pin to see bus idle and be able to synchronize. By default the SBC is in Forced Normal mode, if not try to reset it, i.e. follow steps in example description
BR, Petr
