I want to vary the duty cycle in the run time. So that I can observe the pwm signal. And also want to change the LED brightness using potentiometer. Is it possible to do in the s32ds using s32k144 board?
Solved! Go to Solution.
Hi @Shrini
Yes, it is possible to change the duty cycle of a PWM. You need to change the value of the CnV register
FTM_->CONTROLS[channel].CnV= value;
I suggest you look at the included examples on the SDK/RTD or in the S32K1xx Series Cookbook.
B.R.
VaneB
