openssl offload crypto to hse
eone
Hi,NXP
i am using BSP36.0 on s32g274ardb2, when try use openssl offload crypto operation to hse, its not take effect;What should I do to make it effective?
Here are some outputs:
eone
Hi,NXP
I am verifying the operation you mentioned,When I execute the following command:
ldconfig -l /usr/lib/libpkcs-hse.so.1.0
ldconfig -l /usr/lib/libcrypto.so.3
ldconfig -l /usr/lib/libhse.so.1.0
ldconfig -l /usr/lib/libp11.so.3.4.3
hse-secboot -f -d /dev/mmcblk0
The following error occurred after restarting the machine:
It didn't appear before, how should I solve this problem?
Daniel-Aguirre
We seem to be a little bit confused. We are seeing that in a previous post, you executed these commands and there was no problem, or so it seems.
Can you help us elaborate more on this situation? Was this a clean build?
Please, let us know.
eone
Hi,NXP
this maybe secure boot problem, we have already resolved it
following your last prompts, I tried adding several algorithms:
Testing found no effect, the interrupt about hse in /proc/interrupt did not change;
Is it related to the following implementation? the afalg_ciphers function only aes algorithms
 How should I modify can use other algorithms link AES offload to hse?
Looking forward to your reply, Thanks!!!
