How to query atf fip image info generated from linux bsp package ?
fengxianeric
Hi, I generated fip.s32-qspi and fip.s32-sdcard, but did not see ivt image info from log file under tmp directory,  I want to know entry point address and size formation to fill in bootloader configuration items,
Thanks.
MayanksPatel
Hi @fengxianeric,
Thank you for reaching out to us.
How did you generate fip.s32-qspi and fip.s32-sdcard? Have you separately compiled ATF image?
When compilation completes there will be an IVT table printed on the screen. also, the same mentioned in the BSP UM.
Hope this helps.
Mayank s Patel
