Digitally Controlled DC/DC Buck Converter Reference Design
liujun66
Did you have Digitally Controlled DC/DC Buck Converter Reference Design?
I want to konw digitally Controlled  power supply(etc.BUCK,BOOST).
Did you have some examples of PI regulation applied in power supply?
Thanks!
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
Have you considered a device from our PMIC portfolio?
For example, the PF0100 series features four to six buck converters, depending on configuration and a boost regulator.
Evaluation boards are also available.
I hope this information helps.
David
