Couldnt insert one of the kernel modules in IPCF address already in use error
555 次查看
ashwini2024
S32G3
BSP 40.0
IPCF 4.10
On m core side: AUTOSAR
On a core :Linux
540 次查看
Daniel-Aguirre
Can you help us elaborate more on regards of the setup you are doing? Which commands are you inputting under uboot? Can you help us sharing the whole boot log of your system?
Is the BSP being built manually with yocto? Or are you using the pre-built images provided by NXP?
Please, let us know.
473 次查看
ashwini2024
The below is the boot loG. WE are manually building and not pre built images.
462 次查看
Daniel-Aguirre
Thanks for your feedback. We can recommend using the pre-built images by NXP to isolate any compilation/configuration errors under your custom build. The following community post provides information on regards of manually building the IPCF module and loading into a pre-built image by NXP:
Re: Issue with NXP S32G274A RDB2 -  IPCF - NXP Community
