GNUPlot is still broken in BSP22.0
748 次查看
gert-janrozing
Hello, I still find it amusing that when building the S32V BSP for the s32v234-sbc according to the guide, the build still fails for GNUplot. I have attached the error log. The solution to this problem is easy, by just removing GNUplot from the yocto build itself. However the Problem has been persistent since BSP 18.0.
0 回复数
