RAppID BL Tool
RAppID BL Tool
2,666 次查看
lohrsistemas
I want to use the rappid BL tool to program the s32k144 MCU. What kind of physical interface should I use? Can a USB/Serial converter like a FTDI be? Is there any MCU specific UART for this connection?
标记 (3)
2,293 次查看
jiri_kral
if you are using EVB - you can use OpenSDA interface which is acting as COM port. The boodloader firmware is using LPUART1.
Jiri
2,293 次查看
lohrsistemas
I tried this but the below error occurs:
2,293 次查看
jiri_kral
did you successfully upload the bootloader firmware itself into EVB? (the .rbf file). You can copy it into openSDA mass storage or upload it as normal .srec file.
Jiri
