I integrated CCP driver, Reload the project into workspace but compiler errors occur.
1,414 次查看
ChenBowen
    I integrated CCP driver, and my project works well .  However,  I removed the project and  just reload the project into the workspace,  and so many compiler errors occur.....  I am using S32DS v2.1 with SDK 3.03.
1,396 次查看
Mehul_Patel_NXP
Hi, @ChenBowen ,
Please can you provide more information related to the issue.
It may be because something going wrong with file inclusion, it seems it is including files multiple times.
Please can you check the your code files are proper or not. Sometime it may give error for the not completing brackets.
Please can you share the log for the current workspace :
C:\Users\Public\[workspace_name]\.metadata
Thank you. Best regards.
- Mehul Patel
