I have a board with 9S12C and have a return error message after Hiwave loading like below;
Postload command file correctly executed. ^ Error: unknown identifier ^ Error: expression expected (use BS ? to query syntax) Stop at Function: No function with the name "main" was found.
Thanks for the information. My problem is really on using a existing .abs file to flash the board via the Hiwave.exe and the .abs file is without the debug information, I guess. Can we fix it? Thanks.
