Hello All,
I have to change my micro from a S12G64 to a ZVC19.
In my program, I have a line to read a specific byte in the P-Flash.
The problem in S12G64, the address has been converted from Global Memory Address to Local Memory address, I am not sure I have to do the same thing ZVC...
In S12G64 my code was:
// Addr variable is Global address, for example 0x38010 for a byte in Page 0xE
#define GlobalToLocal(Address) (((Address) & 0x3FFFU) | (((Address) & 0x003FC000UL) << 2U) | 0x8000U)
unsigned char mybyte;
mybyte= *(unsigned char *far)(GlobalToLocal(Addr));
I would like to know if the Following code is right on ZVC:
// In prm, ROM is defined form 0xFD0000 to 0xFFFDFF
// I would like to read Global Address Addr = 0xFE0010
mybyte= *(unsigned char *far)(Addr);
Thank you for your help
there is a difference between MCUs from the memory space point of view. S12Z devices use 24bit linear space only. So for example:
// read the flash
for(addrl=0xFF8000UL; addrl<=0xFF8FFFUL; addrl+=2)
result = PFLASH_Read_Word(addrl);
//PFLASH_Read_Byte
unsigned char PFLASH_Read_Byte(unsigned long int address)
unsigned char data8;
data8 = *(unsigned char *)address;
return data8;
//PFLASH_Read_Word
unsigned int PFLASH_Read_Word(unsigned long int address)
unsigned int data16;
data16 = *(unsigned int *)address;
return data16;
Ladislav
