I think that we found root cause of this issue.
Datasheet says:
Additionally, XGATE interrupts may be raised by the XGATE module by setting one or more of the XGATE channel interrupt flags (by using the SIF instruction). This will result in an CPU interrupt with vector address vector base + (2 * channel ID number), where the channel ID number corresponds to the highest set channel interrupt flag, if the XGIE and channel RQST bits are set.
So, SIF instruction causes CPU interrupt but appropriate Interrupt must be routed to XGATE.
Richard,
RQST=0 makes corresponding XGIF_XX_XX flag not used in any way. And when RQST is set, setting XGIF_XX_XX using XGATE SIF instruction triggers corresponding CPU ISR handler. And when it is made triggered, it will run, no matter is corresponding interrupt mask bit set or not. So if you trigger CAN handler, corresponding CAN mask bit is ignored and you should clear not CAN interrupt flag in CAN ISR, but but corresponding CAN XGIF_XX_XX.
See attached prj. It SIF's PIT0 handler. Try setting breakpoints on XGATE and S12 ISR's and also switching RQST in Xgate setup routine.
Sorry
I can not read C code.
XGIF 58 denary = ID $3A
Vector table listing in S12XE says this is for PIT INT E3
Where as you use PIT INT 0.
What is XGIF_3F_30
And what is CPU doing to PITTF
I think you are triging XGATE with XGSWT1
Then XGATE set XGIF
Why is PIT involved?
You didn't mention above that you are using S12XE. My code is for S12XD. Though, it doesn't matter, PIT0 vector is at the same address on both S12XE and S12XD.
Do you mean this XGIF_3F_30_XGIF_3D_MASK? But it is flag mask for XGATE channel $3D, not $3A. Ant it matches low part of CPU12X vector address divided by 2. PIT0 CPU12X vector address is $FF7A. $7A/2 = $3D.
Well, it is mentioned both in S12XE/S12XD datasheets, also it is defined in both asm and C header files, that come with Codewarrior. By XGIF_XX_XX I meant one of XGIF flags.
I'm sorry you don't understand C. I meant that SIF works only for vectors with RQST=1. SIF doesn't do anything useful in case target channel has RQST=0.
When RQST=1, there can be two scenarios:
Hope it is more clear.
Possibly
I understood MC9S12XE-Family Reference Manual Rev. 1.24 that:
10.5.2 Outgoing Interrupt Requests
There are three types of interrupt requests which can be triggered by the XGATE module:
4. Channel interrupts
For each XGATE channel there is an associated interrupt flag in the XGATE interrupt flag vector
(XGIF, see Section 10.3.1.8, “XGATE Channel Interrupt Flag Vector (XGIF)”). These flags can be
set through the "SIF" instruction by the RISC core. They are typically used to flag an interrupt to
the S12X_CPU when the XGATE has completed one of its task.
AND
Table 6-8. INT_CFDATA0–7 Field Descriptions
Field Description
7
RQST
XGATE Request Enable—This bit determines if the associated interrupt request is handled by the CPU or by
the XGATE module.
0 Interrupt request is handled by the CPU
1 Interrupt request is handled by the XGATE module
I have RQST = 0 as I want CPU to service it.
Datasheet says:
No I tested using the XGSWT interrupts directed to CPU, that works fine, but this route is usually to request XGATE actions.
And there a lot more XGIF s, which is more real world.
But fair question HSW
XGATE code
LDL R3,#$38 ;XGIF Interrupt S12 XGSWT1
SIF R3
; LDWD R3,$0202
; LDWD R4,XGSWT
; STW R3,(R4,#0) ;SWT INT
CPU
MOVB #$01,XGIF+8 ;CLEAR FLAG ID $38 (56d)
MOVW #$0200,XGSWT ;CLEAR XGSWT1
MOVW TCNT,DEBUG7 ;used to check latency
INCW DEBUG8
RTI
If I set XGSWT1 CPU interrupt runs fine:
DEBUG8 increments
Both XGSWT1 and XGIF ID=$38 cleared
But as shown no XGSWT1 no CPU interrupt no DEBUG8 incrementing.
I assume XGIF ID=$38 is NOT for XGSWT1 but then documentation must be wrong.
Richard
Richard,
you're not showing your S12XINT setup, so I assume that the XGATE software trigger 1 is routed to the XGATE.
In your example, the XGATE code that would set XGSWT1 is commented out. And if it wasn't, you would have a race condition. The XGATE would re-trigger as long as the CPU does not clear the XGSWT1 bit while the XGATE is executing the code in-between the "STW R3,(R4,#0)" instruction and the next RTS. As soon as the CPU would hit this time window, the software trigger would remain cleared.
