i2c switch
i2c switch
1,360件の閲覧回数
mrharmonsr
I'm curious about the analog switches used on the I2C buses.  Some I2C devices are connected directly to the bus, while a few go thru a switch.  Why?
1,225件の閲覧回数
estephania_mart
You can check the block diagram of all the components of the kit in this link. I believe you are referring to the NX3L2267, there you will find the data sheet.
Hope it helps!
