MMC read: dev # 0, block # 18432, count 128 ...
Card did not respond to voltage select! : -70
MMC: block number 0x4880 exceeds max(0x0)
Fman1: Data at 00000000f7a245f0 is not a firmware
Fman1: Data at 00000000f7a34600 is not a firmware
Fman1: Data at 00000000f7a44610 is not a firmware
Fman1: Data at 00000000f7a54620 is not a firmware
flexbuild18.06
=> mmc info
Device: FSL_SDHC
Manufacturer ID: d6
OEM: 103
Bus Speed: 52000000
Mode : MMC High Speed (52MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 4 MiB
User Capacity: 7.3 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 4 MiB ENH
=>=> mmc info
Device: FSL_SDHC
Manufacturer ID: d6
OEM: 103
Bus Speed: 52000000
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 4-bit
flexbuild_lsdk2108 error
Did you get the following error in u-boot booting up log? Did you get this error with LSDK18.06 image? Would you please provide the whole console log?
