We are LS1043A in our design, can you please confirm shall we use UART2 as the Debug port? we have connected UART1 with Network Switch.
Look at the Section 2.3.1 of the LS1043ARDB Reference Manual:
This Section contains instruction for using UART2 as terminal.
Pavel Chubakov
Thanks for your reply. So we can use any of the UART port as Debug terminal.
Also in the Debug port we are using CTS and RTS pins and UART which connected to Switch does not use CTS and RTS. If that is the case i hope we shall not configure the CTS and RTS of UART which is connected to Switch as GPIO. Please confirm my understanding.
