Error in flex-builder command
anesarkar
   I am getting the following error in flex-builder after executing following command ->
flex-builder -i merge-component -a arm64
INSTRUCTION: merge-component
DESTARCH: arm64
[sudo] password for anish:
/sbin/ldconfig.real: /usr/local/lib/libOpenVG.so is not a symbolic link
/home/anish/Desktop/flexbuild/tools/flex-builder: line 1423: cd: /home/anish/Desktop/flexbuild/packages/linux/linux: No such file or directory
Can someone tell me how to handle this problem? I am trying to build ubuntu image on sd card for LS1028ARDB.
anesarkar
I still get the error of
Any solution for this?
yipingwang
If there is problem to execute command "flex-builder -i merge-component -a arm64" to merge Freescale special apps and Kernel modules into rootfs filesystem, you could copy app_components_LS_arm64.tgz  and lib_modules_LS_arm64_<version>.tgz to the target board and deploy them to rootfs directly.
After executing "flex-builder -i mkrfs -a arm64", you will get Ubuntu rootfs filesystem, after deploy it to SD or SATA and boot up the system, please copy app_components_LS_arm64.tgz and lib_modules_LS_arm64_<version>.tgz to the target board to do the following operations.
$ tar -xzvf app_components_LS_arm64.tgz
$ cp -r components_LS_arm64/*  /
$ tar -xzvf lib_modules_LS_arm64_4.19.26.tgz
$ cp -r 4.19.26/*  /lib/modules/<version>/
Yiping
yyu2
Hi Yiping,
Regarding "/sbin/ldconfig.real: /usr/local/lib/libOpenVG.so is not a symbolic link", is there any workaround for it now?
Pavel
Use the following command sequence:
$ flex-builder -i mkrfs -a arm64
$ tar xvzf app_components_LS_arm64.tgz -C build/apps
$ sudo tar xvzf lib_modules_LS_arm64_4.14.104.tgz -C build/rfs/rootfs_lsdk_19.03_LS_arm64/lib/modules
$ sudo tar xvzf lib_modules_LS_arm64_4.19.26.tgz -C build/rfs/rootfs_lsdk_19.03_LS_arm64/lib/modules
flex-builder -c linux -a arm64
Pavel Chubakov
This thread is continued as a private discussion with the submitter,
NXP support is not following the thread anymore.
yipingwang
Hello Anish Nesarkar ,
Please execute "flex-builder -i mkrfs -a arm64" first, then execute "flex-builder -i merge-component -a arm64".
Please refer to the following procedure.
1. Generate Ubuntu arm64 userland
2. Extract app components or kernel modules
$ sudo tar xvzf lib_modules_LS_arm64_<kernel_version>.tgz -C build/rfs/rootfs_ubuntu_bionic_LS_arm64/lib/modules
3. Merge all components packages and kernel modules into target userland and compress ubuntu arm64 rootfs as .tgz tarball
$ flex-builder -i merge-component -a arm64
$ flex-builder -i compressrfs -a arm64
Yiping
nxf54443
Hi Yiping,
I am using Linux 18.03 (docker container for 18.03 on 16.04 host) and am working on LSDK 19.03.
I have executed the exact same commands as you have mentioned in the post here.
The second last command i.e. "$ flex-builder -i merge-component -a arm64" worked perfectly fine,
but the last one i.e. "$ flex-builder -i compressrfs -a arm64" shows the following error,
INSTRUCTION: compressrfs
DESTARCH: arm64
invalid instruction: compressrfs
Can you explain the reason behind this error and the way to fix it ?
sameer_chouksey
Hello tarunchawla127@gmail.com,
I am facing exact same issue. Did you find some solution to this??
Sameer
940849422
Hello
      It's the same problem for me. How did you solve it?
        Thank you
anesarkar
     I followed all those steps. I did get the two .tgz files. I am getting error at $ flex-builder -i merge-component -a arm64 but not at $ flex-builder -i compressrfs -a arm64.
So, I do get the final compressed file. But, I don't know if the final compressed file is correct because this command "$ flex-builder -i merge-component -a arm64" failed.
Later, when I try to load the image on board using usb and flex-installer " boot partition and ubuntu rootfs" using sd card, I get the following error
