Error in flex-builder command
18,955 次查看
anesarkar
   I am getting the following error in flex-builder after executing following command ->
flex-builder -i merge-component -a arm64
INSTRUCTION: merge-component
DESTARCH: arm64
[sudo] password for anish:
/sbin/ldconfig.real: /usr/local/lib/libOpenVG.so is not a symbolic link
/home/anish/Desktop/flexbuild/tools/flex-builder: line 1423: cd: /home/anish/Desktop/flexbuild/packages/linux/linux: No such file or directory
Can someone tell me how to handle this problem? I am trying to build ubuntu image on sd card for LS1028ARDB.
9 回复数
18,266 次查看
anesarkar
I still get the error of
Any solution for this?
18,266 次查看
yipingwang
If there is problem to execute command "flex-builder -i merge-component -a arm64" to merge Freescale special apps and Kernel modules into rootfs filesystem, you could copy app_components_LS_arm64.tgz  and lib_modules_LS_arm64_<version>.tgz to the target board and deploy them to rootfs directly.
After executing "flex-builder -i mkrfs -a arm64", you will get Ubuntu rootfs filesystem, after deploy it to SD or SATA and boot up the system, please copy app_components_LS_arm64.tgz and lib_modules_LS_arm64_<version>.tgz to the target board to do the following operations.
$ tar -xzvf app_components_LS_arm64.tgz
$ cp -r components_LS_arm64/*  /
$ tar -xzvf lib_modules_LS_arm64_4.19.26.tgz
$ cp -r 4.19.26/*  /lib/modules/<version>/
Yiping
18,266 次查看
yyu2
Hi Yiping,
Regarding "/sbin/ldconfig.real: /usr/local/lib/libOpenVG.so is not a symbolic link", is there any workaround for it now?
18,266 次查看
Pavel
Use the following command sequence:
$ flex-builder -i mkrfs -a arm64
$ tar xvzf app_components_LS_arm64.tgz -C build/apps
$ sudo tar xvzf lib_modules_LS_arm64_4.14.104.tgz -C build/rfs/rootfs_lsdk_19.03_LS_arm64/lib/modules
$ sudo tar xvzf lib_modules_LS_arm64_4.19.26.tgz -C build/rfs/rootfs_lsdk_19.03_LS_arm64/lib/modules
flex-builder -c linux -a arm64
Pavel Chubakov
This thread is continued as a private discussion with the submitter,
NXP support is not following the thread anymore.
18,266 次查看
yipingwang
Hello Anish Nesarkar ,
Please execute "flex-builder -i mkrfs -a arm64" first, then execute "flex-builder -i merge-component -a arm64".
Please refer to the following procedure.
1. Generate Ubuntu arm64 userland
2. Extract app components or kernel modules
$ sudo tar xvzf lib_modules_LS_arm64_<kernel_version>.tgz -C build/rfs/rootfs_ubuntu_bionic_LS_arm64/lib/modules
3. Merge all components packages and kernel modules into target userland and compress ubuntu arm64 rootfs as .tgz tarball
$ flex-builder -i merge-component -a arm64
$ flex-builder -i compressrfs -a arm64
Yiping
18,266 次查看
nxf54443
Hi Yiping,
I am using Linux 18.03 (docker container for 18.03 on 16.04 host) and am working on LSDK 19.03.
I have executed the exact same commands as you have mentioned in the post here.
The second last command i.e. "$ flex-builder -i merge-component -a arm64" worked perfectly fine,
but the last one i.e. "$ flex-builder -i compressrfs -a arm64" shows the following error,
INSTRUCTION: compressrfs
DESTARCH: arm64
invalid instruction: compressrfs
Can you explain the reason behind this error and the way to fix it ?
18,266 次查看
sameer_chouksey
Hello tarunchawla127@gmail.com,
I am facing exact same issue. Did you find some solution to this??
Sameer
18,266 次查看
940849422
Hello
      It's the same problem for me. How did you solve it?
        Thank you
18,266 次查看
anesarkar
     I followed all those steps. I did get the two .tgz files. I am getting error at $ flex-builder -i merge-component -a arm64 but not at $ flex-builder -i compressrfs -a arm64.
So, I do get the final compressed file. But, I don't know if the final compressed file is correct because this command "$ flex-builder -i merge-component -a arm64" failed.
Later, when I try to load the image on board using usb and flex-installer " boot partition and ubuntu rootfs" using sd card, I get the following error
