oks
i have to MC9S08DZ128MLL connected by RS232 interface, but one of them has an LCd display attached where all messages send by rs232 are displayed
both have the exact same code
i'm using processor expert libraries
i called SendChar at the main and it works
i called RecvChar from the OnRxChar interrupt and works
i called SendBlock at the main and it works
but i called RecvBlock from the OnRxChar interrupt and doesnt work
i assume it doesn't work because the interrupt is just for one char and i'm getting a lot of them
but if i cant use OnRxChar, then which other interrupt should i use?
(or maybe i'm messing up pointers?)
i'll send you my code
thank you
Original Attachment has been moved to: myINT-code.txt.zip
Original Attachment has been moved to: myLCD-code.txt.zip
Original Attachment has been moved to: PE-code.txt.zip
解決済! 解決策の投稿を見る。
The problem is that the RecvBlock method of the AsynchroSerial component is not intended to be called within OnRxChar event, which is called after reception of every character.
If you'd like to use RecvBlock method, use it from the main routine or from the OnFullRxbuf event.
Example of the OnFullRxBuf event code from the 'Typical usage' page of the component help. You can access this page using the pop-up menu command 'Help on component' :
void AS1_OnFullRxBuf(void)
word Received;
byte err;
err = AS1_RecvBlock((byte*)&message, sizeof(message), &Received);
best regards
Petr Hradsky
Processor Expert Support Team
word Received;
byte err;
best regards
Petr Hradsky
