System Oscillator Enabled isn't Reflected in MCG Settings
ソリューションへジャンプ
2,436件の閲覧回数
chiasyan
I am having trouble to set the MCG mode to PEE due to the issue mentioned. Is it a bug or I am doing it wrong?
Thank you.
タグ(5)
2,333件の閲覧回数
chiasyan
Close and re-open the project solved the issue.
2 返答(返信)
2,334件の閲覧回数
chiasyan
2,333件の閲覧回数
Monica
Senior Contributor III
That's great Chiasyan!
Would you mind sharing how you solved it out?
Monica
