I am working with CodeWarrior 5.1 for S12(X). My target is 9S12XA256.
I am adding the FreeCntr component and setting it up to be an output compare that interrupts at a specified rate.
There is no way to disable the interrupt event. The Enable/Disable Event methods are grayed out in Processor Expert and nothing I do will enable them. I tried connecting it to different timer sources, shared timers, individual PIT timers, etc. Nothing works. The Enable/Disable events are always grayed out.
How do I stop this FreeCntr componet from interrupting when I do not need it anymore? Aside from going directly to the registers myself with my own code, I think there is something seriously wrong with this component and the way it was implemented.
解決済! 解決策の投稿を見る。
The events in the Events tab have to be enabled first before the Enable/Disable methods will be activated in the Methods tab.
