ADC_LDD
ADC_LDD
736件の閲覧回数
mehdikarimibiuk
Contributor V
I need to employ ADC for one my A/D channel pin (ADC0_DM1) on the freescale processor MK60DN512VLL10 that we have. I am using processor expert for this. When I add the ADC_LDD component, setting parameters in properties tab, there is a section for conversion time, single conversion time, additional conversion time, etc. Whatever number I put in there, I get errors. Do you know what I should put in? can you send a sampler for this component? Thanks
タグ(3)
495件の閲覧回数
ZhangJennie
Hi Mehdi,
you can see ADC processor expert sample in {CW10.6 install}\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K40X256\DAC_ADC
the sample is for K40 but the method is the same for k60.
Hope this helps!
this answer is for you, if it helps, please click on "correct answer" button. thanks!
Zhang Jun
