run hpcNet8641d bsp vxworks problem
1,236 次查看
jacktom
I used hpcNet8641d bsp build vxworks image and run it in simulation,but  can't  put shell prompt and command, I find the progrom run to shellGenericInit() function taskdelay(1) and  not  return ,last  run into idleEnter() function,this is why not print “->”  and  run into idleEnter()?   Kernel configure has add WDB and shell components 。somebody knowns why please tell me .thanks very much!
1 回复
1,174 次查看
ufedor
Please address your request to the Wind River technical support.
