MPC8641-HPCN Board is not booting linux at 1Ghz core frequency...
989 次查看
ashishkhetan
I am using MPC8641-HPCN based custom board and able to boot linux at MPX clock 400Mhz and core clock 800mhz. When I am increasing core frequency ie MPX clock at 400Mhz and core at 1Ghz, kernel stuck. Does any body have faced this kind of issue ?  Or any idea how to resolve this?
Thanks & Regards
@shish
729 次查看
alexander_yakov
Please verify if the same problem appears on Freescale HPCN board you used for reference.
729 次查看
Wlodek_D_
Senior Contributor II
Thank you for your post, however please consider moving it to the right community place (e.g. PowerQUICC Processors ) to get it visible for active members.
For details please see general advice Where to post a Discussion?
Thank you for using Freescale Community.
